23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> rendering problem
1 Posts No Rating |
hi there, ineed help, i m using revit 2009, my laptop processor is core 2 duo, 3 gb ram i want to render a casino image with high resolution, it has 343 lights, when i keep it to render 1 image of 90 X 60 @ 600 res. & draft takes 24 hrs and since the resolution is less the image is no good
There is no real problem here - you are not doing anything wrong except you are expecting way too much. This is a very complicated image and it will take a very long time to render..... if it can at all on your system. REVIT is a BIM program - not a rendering program. It may be best to take something this complicated into a larger system with more power and a different render engine.
sounds like a job for a 3d Max like program, (341 lihjts).
definatley one for max.
Revit 2009 Rendering Problem(Black screen) [ 1 2 ] |
Mon, Apr 1, 2013 at 2:45:28 PM
27
Rendering Problem |
Wed, Feb 6, 2013 at 1:41:48 PM
Problem while rendering |
Tue, Feb 12, 2013 at 1:37:23 AM
rendering |
Thu, Jan 26, 2012 at 11:54:10 AM
rendering problem with windows |
Fri, Jan 13, 2012 at 3:31:28 PM
