Forums >> Revit Building >> Technical Support >> sweep visibilty
Wed, May 4, 2005 at 2:34:09 PM | sweep visibilty
kfpopeye
I'm trying to use a family parameter to toggle the visibilty of the frames around OH sectional doors. I used a sweep for the frame and set the visible setting to a Yes/No parameter but nothing seems to happen. Is this true with everyone here?
Life is one of those things that people find hard to avoid. - Rowan Atkinson
Wed, May 4, 2005 at 7:03:51 PM | RE: sweep visibilty
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Providing everything is linked correctly, You may not notice the difference at first but when the sweep is set to be invisible, (in the family) the sweep will still be visible, but the linework will change to a grey colour. This indicates it will not be visible when loaded into a project. HTH.
Thu, May 5, 2005 at 4:03:34 PM | RE: sweep visibilty
kfpopeye
HTH.This was loaded into a project. The odd thing is it did shouw grey in the family editor but nothing happened in the project.
This should work though? I know there are still some areas where visible settings don't work.
Thu, May 5, 2005 at 6:46:12 PM | RE: sweep visibilty
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes it should work. What areas where visibilty doesn't work?? Attach the file if you'd like and i'll have a look when i get a chance.
Fri, May 6, 2005 at 12:41:01 PM | RE: sweep visibilty
kfpopeye
From what I hear. You can't toggle void extrusions on and off.
Sun, May 8, 2005 at 6:00:22 PM | RE: sweep visibilty
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
That's true you cannot toggle a void extrusion from cutting or not cutting. (its already invisible). Only method is to have a parameter when set to not cut changes the void parameters so it no longer intersects the solid and therefore doesn't make a cut.
Thu, May 12, 2005 at 7:48:31 PM | RE: sweep visibilty
kfpopeye
AHA!!!! Got it. My door used some voids to cut openings in the panels for windows. I noticed today when I selected the frame sweep that the voids would also highlight. I used the "Do Not Cut" tool to seperate them and the sweep would dissappear when turned off. Thanks for the help guys. Smile) Post edited on 2005-05-12 19:49:08
Wed, Nov 18, 2009 at 9:52:44 AM | sweep visibilty
paulcorb
2 Stars: 1 Votes
can you tell me were to look for the camera in revit 2008 , so i can set up for rendering ? a 3d perspective view i am completely new to revit and i am using r 2008
Wed, Nov 18, 2009 at 12:51:27 PM | sweep visibilty
tim123
4 Stars: 19 Votes
View / New / Camera
Visibilty issue
Wed, Jun 22, 2005 at 10:59:40 PM
Problem with wall sweep show on wrong sections
Wed, Mar 22, 2006 at 5:37:32 AM
Wall Sweeps in Visibilty Graphics
Wed, Jan 20, 2010 at 12:10:08 PM
Visibilty Graphics Greyed Out
Fri, Nov 22, 2013 at 10:42:50 AM
Can You Flex a Sweep in Components
Mon, Jun 3, 2013 at 2:09:23 PM
Page generation time: 0.4065
