Forums >> Revit Building >> Technical Support >> Import PDF's
Mon, Oct 13, 2008 at 3:11:16 PM | Import PDF's
morss
Is there anyway to import a PDF into a revit drafting detail?
Morss Medical Architecture
Mon, Oct 13, 2008 at 3:24:57 PM | Import PDF's
4 Stars: 205 Votes
I don't think so, but with "AllPlan Version 2008" you can import PDF and "He" convert pdf file in "Lines" then it just export to dwg...
Edited on: Mon, Oct 13, 2008 at 3:26:43 PM
Mon, Oct 13, 2008 at 10:17:29 PM | Import PDF's
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
No, but if you have Adobe Acrobat you can open and save it as a JPG.  If you don't you can do a screenshot of it and save out the image and import that...
Regards,
Chris.
Tue, Oct 14, 2008 at 7:24:38 AM | Import PDF's
coreed
coreed Avatar
4 Stars: 16 Votes
also if you adobe illustrator you can open it, save out as dwg and bring that into revit.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
PDF's & Excel
Mon, Dec 12, 2016 at 6:17:38 PM
Printing PDF's
Tue, Oct 26, 2010 at 11:21:57 AM
Autocad imports PDF's. Is there anyway Revit does that?
Mon, Feb 1, 2010 at 5:06:18 PM
Problem import Autocad file that contains ''proxy entities''.
Wed, Mar 17, 2021 at 7:38:19 AM
Can't figure out PDF printing. Help!
Tue, Sep 12, 2006 at 4:39:07 PM
Page generation time: 0.5657
