Forums >> Revit Systems >> Technical Support >> Automatic Annotation ?
Mon, Oct 13, 2008 at 8:55:55 AM | Automatic Annotation ?
caduk
Hi there,
In abs when you drew up some ductwork, you had an option you could tick that turns duct size annotation and flow arrows on/off.
Now im using revit MEP 2009 and i cant seem to find any options like that. The only way i see is by drawing it all > then going around and tagging it. For the sake of being lazy does anyone know of an option in revit that will help?
Cheers
Thu, Oct 16, 2008 at 10:58:27 AM | Automatic Annotation ?
caduk
Ok i found the solution.... a simple icon that says "on/off tag on placement" when you click the duct/pipe tab...
xD
 Now is there anyway to remove the unit type? i want to remove the mm (i.e. 200mmx200mm)
Tried editting the tag etc but cant seem to find a way.
 Any help would be sweet as.
automatic annotations?
Thu, Mar 1, 2007 at 6:43:51 AM
Object Count Annotation
Fri, Feb 11, 2005 at 4:06:29 PM
Automatic extension gate
Wed, Dec 26, 2012 at 11:56:03 AM
Annotation Object Styles [ 1 2 ]
Thu, Dec 17, 2009 at 11:56:38 PM
15
sloped annotation symbol text
Mon, Aug 15, 2011 at 8:04:20 PM
Page generation time: 0.0693
