Forums >> Revit Building >> Technical Support >> Problem creating railing with intermediate newel posts
Mon, Oct 13, 2008 at 8:52:40 AM | Problem creating railing with intermediate newel posts
jfmonod
Hi,
 I'm trying to create a balcony railing with intermediate posts every 5' and balusters every 4". What I end up with is the intermediate posts every 5' and ONE baluster offset 4" from the posts each time. So it's post, baluster, big empty space, repeat. What am I doing wrong ?  : )
 Many thanks,
 JF
Mon, Oct 13, 2008 at 2:49:00 PM | Problem creating railing with intermediate newel posts
mthurnauer
3 Stars: 2 Votes
You need to define the entire pattern from post to post.  So, if you want to have a pattern that repeats every five feet with a post and then ballusters at 4" o.c. between the posts, make a pattern that is something like this (Post - distance from last = 6", 3/4" square balluster - distance from previous - 6", 3/4" square balluster - distance from previous - 4", 3/4" square balluster - distance from previous - 4".......keep on adding ballusters in until the field for Pattern Length is 5'-0".
Mon, Oct 13, 2008 at 2:56:10 PM | Problem creating railing with intermediate newel posts
robinballew
robinballew Avatar
3 Stars: 4 Votes
Also on long runs you can just add a "Split" in the sketch line. At the split it will use the Newel defined for Corner post.
BallewDesigns.com
Mon, Oct 13, 2008 at 3:20:07 PM | Problem creating railing with intermediate newel posts
jfmonod
 Split the line...... duhhhhh.  Thank you thank you thank you. That's what i needed.
And I'm guessing I'd use the "define the entire pattern" option if I had different panels within the same railing.
Thank you both.
JF
Sat, Oct 10, 2009 at 12:12:01 PM | Problem creating railing with intermediate newel posts
Prophecy99
Prophecy99 Avatar
spliting the line SWEET, thanks robin
Imagination reveals truths reality obscures.
intermediate posts in railings
Tue, Oct 12, 2021 at 12:27:49 PM
Baluster inside Newel Post revit 2014
Wed, Mar 26, 2014 at 2:54:06 AM
plan view cut plane inexplicably omits objects that it cuts.
Tue, Mar 3, 2009 at 3:54:46 AM
Railing Posts Alignment
Thu, Dec 4, 2008 at 8:10:43 PM
stair newel post does not go to treads
Mon, Sep 19, 2011 at 1:57:25 PM
Page generation time: 0.5334
