Forums >> Workflow & Implementation >> Worksets >> Load workset from Linked file?
Mon, Oct 13, 2008 at 3:07:48 AM | Load workset from Linked file?
dexter303
Does anybody know if it is possible to partial open/load a linked file using worksets?
I have many houses on a site file linked, and i what to only load my fasdads worksets that are in the linked files.
 /Thanks in advance
Tue, Oct 14, 2008 at 12:11:23 PM | Load workset from Linked file?
NKramer
4 Stars: 9 Votes
Yes you can. You have to select the little arrow to the right of the open button. Then you will see that by default you are opening all worksets. You can change this to specify worksets (similar to openin specific worksets). The only downfall I have seen is that once you chose to load/ unload  workset you have to go back and "reload from" in order to get back to a point where you can chose which worksets should/ should not be loaded.
HTH
Nick
Workset Visibility Issues In Linked File
Wed, May 7, 2008 at 2:19:36 PM
linked file elements on host workset...help
Fri, May 4, 2012 at 5:46:58 AM
Nested Link in nested link workset control?
Fri, Feb 28, 2020 at 5:19:24 AM
? regarding controlling visiblity within linked files according to Worksets
Fri, Jul 2, 2010 at 10:01:40 AM
Filters VS Workset for Linked Files
Wed, Feb 22, 2012 at 9:45:17 AM
Page generation time: 5.0412
