10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Walls do not show up in plan view
2 Posts No Rating |
I have walls starting at the 1st level and ending at the roof. Floor plan of the 2nd level does not display the walls. I have tried everything I know that could have hidden them (viewport visibility and view range), but I still cant get the walls to show up. All the other levels dispay them, except for level 2. Are there any other uncommon settings that affect the display properties of walls in the certain view? Thank you
Did you go in that levet to VG and check "Walls" if are turned on? can you put the model here to download to take a look???
2 Posts No Rating |
I did check that and they are on. I actually was able to figure it out. I changed (sometime in the past probably late in the night) the view settings to 'structural' vs 'architectural' and that is why my walls were off. So silly!!! Thank you so much for you help though, I really appreciate you responding. Rinara
I have a similiar problem in RA2009. I moved some walls, floors, stairs, etc. (only model elements) to the south 3/8" and now the elements are not showing up in a mezzanine view. I can see them fine in the floor plan and 3D view but not the mezzanine view. I went to the 3D view to select everything and made sure I filtered everything. I checked all the vg settings and view range settings and nothing has changed. I even saved and closed out of the drawing to see if they would show up after I reopened but it didn't work. Any suggestions.
My walls do not appear in an underlay on my roof plan. |
Fri, May 29, 2009 at 7:27:34 AM
Is there a way to force walls to show section? |
Tue, Aug 4, 2015 at 7:40:31 PM
Walls show up on Second Level plan |
Wed, Dec 19, 2018 at 8:39:24 AM
Walls not showing in plan region |
Mon, Feb 18, 2008 at 1:59:12 PM
14
Roof hides walls in plan view |
Mon, Apr 20, 2015 at 7:48:45 AM
