Forums >> Revit Building >> Technical Support >> Brick & frame wall modification
Fri, Oct 10, 2008 at 11:04:24 PM | Brick & frame wall modification
daryl
I need a brick & frame wall with the brick bottom offset 10" lower than the rest of the wall components. I think there is a way to do this by editing the structure, but I haven't been able to figure it out. Any workable methods will be greatly appreciated.
I have attached a PDF of what I need the wall to do.
 Daryl Stockton
Sat, Oct 11, 2008 at 1:41:11 PM | Brick & frame wall modification
coreed
coreed Avatar
4 Stars: 16 Votes
is this what you want
http://screencast.com/t/xPjfjXIggYq
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Oct 13, 2008 at 3:22:31 PM | Brick & frame wall modification
daryl
Thanks Coreed,
I'll give that a try.
 Daryl
Door in brick wall
Mon, Jun 25, 2007 at 2:22:07 PM
Help needed with external brick leaf wrap to cover window frame. RA2008
Mon, Dec 10, 2007 at 5:24:53 AM
Control Position of Door Frame/Panel in Wall Thicker Than Door Frame
Thu, May 6, 2010 at 7:29:41 AM
brick sill below window on brick wall
Thu, Mar 13, 2008 at 6:10:23 PM
Door & HM frame w/ 4" head
Fri, Dec 21, 2007 at 7:05:40 AM
Page generation time: 2.7937
