Forums >> Revit Building >> Tips & Tricks >> Don't know why i didn't think of this sooner....
Fri, Oct 10, 2008 at 5:29:52 PM | Don't know why i didn't think of this sooner....
bradleymatthew
You all have probably been doing this for a while, but.....I created a series of Line Based Detail Components that represent the typical items that I've been drawing in details typically with Detail LInes (Tyvek, Weatherproofing Membrane, etc.) - by making them Detail Components they can now accept tags and, better yet, keynotes (for those of you using keynotes to add text to your views).
Change it once......beautiful.
Bradley
Sun, Oct 12, 2008 at 7:58:36 AM | Don't know why i didn't think of this sooner....
Keynotes do not have to be assigned to be able to use them but they do have to initially point at a detail/model element.  Using the user settings, you can pick the keynote and as with all tags, setting the end to free llows yo to move them anywhere.
Mon, Oct 13, 2008 at 12:53:08 PM | Don't know why i didn't think of this sooner....
bradleymatthew
That's correct, but now i can assign a specific keynote to a specific line element rather than constantly using Keynote User.  I don't really like Keynote User simply becuase if you're not consistant with what the host object is (or if you're like me you forget what the host is...) then you run the risk of changing, erasing, or moving that object
Bradley
BEWARE - Parameters don't update.
Thu, Sep 1, 2005 at 11:36:58 PM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Problem import Autocad file that contains ''proxy entities''.
Wed, Mar 17, 2021 at 7:38:19 AM
Window's dimension don't show up in the window schedule
Fri, Aug 17, 2012 at 1:34:43 PM
Add ''scale'' on a drawing list, when it is not under ''available fiel
Thu, Jan 12, 2012 at 8:35:32 AM
Page generation time: 3.9279
