Forums >> Revit Building >> Technical Support >> Custom Mullion Profile
Fri, Oct 10, 2008 at 1:35:06 PM | Custom Mullion Profile
jstephen
I made a mullion profile for a SSG type of application and when I put it into my project the glass panels do not trim correctly- see attached image.  Is there a way to make the glass panels extend to the actual mullion?
I am using Revit Architecture 2009.
Thanks in advance!
Fri, Oct 10, 2008 at 3:43:59 PM | Custom Mullion Profile
4 Stars: 205 Votes
Is that the dimension you want to the mullions? Check the Family type and see if there is all parameters like you want, put here the "Mullion Family" and i take a look...
Mon, Oct 13, 2008 at 7:29:50 AM | Custom Mullion Profile
jstephen
I took the "rectangular mullion" family, made a duplicate, saved as, then edited it using the dimensions from the kawneer catlaog.
Mon, Oct 13, 2008 at 7:53:12 AM | Custom Mullion Profile
Without seeing exactly what you did, we can't comment a lot.  Do you understand how families, parameters and reference planes work?
The mullion family that is pre-loaded is set up so that you can modify its size through type variables (parameters).  The variables change the location of reference planes in the family and since the geometry is locked to the reference planes, it too is changed.
For most modelling, using the pre-loaded muillions and setting the type variables is sufficient for the model but not detailing.
Edited on: Mon, Oct 13, 2008 at 7:55:01 AM
Mon, Oct 13, 2008 at 3:06:55 PM | Custom Mullion Profile
mthurnauer
3 Stars: 2 Votes
When you make a custom mullion profile, you will see the text in the mullion family that reads,"Curtain Panels are trimmed to where the profile sketch intersects the Center (Front/Back) Ref Plane."  So, if lines of the wide portion of the mullion touch the Cebter Front/Back line, it will use that width to trim the panel.  See the attached images.  I think this will do what you want.  Note that I made a new rectangular mullion using the custom profile and then I had to adjust the Offset of the mullion to pull it forward to be in plane with the glass.
Tue, Oct 14, 2008 at 8:17:26 AM | Custom Mullion Profile
jstephen
That worked great.  I was afraid I would have to adjust all of the panels but your post worked like a charm!
Thank you!
Thu, Apr 23, 2009 at 3:47:59 PM | Custom Mullion Profile
jipper69
can either of you help with non-rectangular mullions and how they join?  why do the mullions always trim to an imaginary rectangle made up by the outtermost extents of the geometry?
How do you edit mullion profile parameters
Thu, Oct 27, 2011 at 10:42:17 AM
Mullion Profile
Tue, May 16, 2006 at 10:37:15 AM
curtain wall mullions
Thu, Apr 5, 2012 at 1:16:07 AM
Custom Curtain wall mullions...please help!!!!
Sat, Apr 25, 2009 at 8:36:15 AM
L Corner Mullion - Can't load profile
Wed, Oct 9, 2013 at 4:37:25 PM
Page generation time: 0.3985
