9 Users Online (7 Members):
Forums >> Revit Systems >> Technical Support >> void extrusion not cutting solid extrusion
I have a roof drain which I am trying to use a void extrusion for the pattern on the top. All the other voids in the family worked fine, however this particular void will not cut! Interestingly enough it will also not allow me to change the plane its drawn too either. Please help!!! I am very close to turning off the monitor and walking away!
Like i just saw in "Downloads" you did solve the problem, isn't???
Thanks! Sometimes I just have to get up and walk away, I just re-created the void form and it worked fine!
Yeah, i saw that...
Cut a void from an extrusion |
Thu, Feb 19, 2015 at 1:08:44 AM
Void extrusion family visibility |
Fri, Apr 22, 2022 at 7:57:52 AM
Void Extrusion in window family problem |
Mon, May 18, 2015 at 3:55:23 PM
Void Extrusion |
Tue, May 28, 2013 at 8:15:38 PM
Make void extrusion permanent |
Wed, Feb 9, 2022 at 6:46:57 PM
