Forums >> Revit Building >> Technical Support >> Partial Visibility in Elevation (plan region)
Thu, Oct 9, 2008 at 12:37:13 PM | Partial Visibility in Elevation (plan region)
twhisker
2.5 Stars: 5 Votes
The building has 5 large bays.  In each bay is a storefront window that has a sunscreen in front of it.  I want to hide 2 of them, show 2 of them and show half of the one in the center.  In CAD, I would draw a diagonal break line and draw the sunshade on one side and the window on the other.  Is there a way i can partially hide an element.  I'm looking for something similiar to plan region where I can change the depth of that particular spot.  Any ideas?  Thanks.
Revit Architecture 2010
Thu, Oct 9, 2008 at 1:06:49 PM | Partial Visibility in Elevation (plan region)
4 Stars: 205 Votes
Hi, by your image and what do you want i think you must use the "Filled Region" to do that, you can pick in the 2 left windows and go to "Override Graphics in View" "By Element" and turn OFF those, but the problem is the Center Window, you want HALF visible and the other Invisible, so...
Thu, Oct 9, 2008 at 1:57:48 PM | Partial Visibility in Elevation (plan region)
twhisker
2.5 Stars: 5 Votes
HUH??  You didnt finish - ha ha.  Yes I know that I have the sunshades hidden on the right by using hide element.  I didn't bother to hide the windows on the left because there are portions you may or may not see behind the sunshade - thats ok.  What I want to do is a 'partial" element hide in view.  If it were a floor plan, I can use plan region.  I wonder if anyone has done soemthing similiar in elevation.  Most likely I will have to use the masking region and then drafting lines for the window.  I was trying to be slick and automated - probably not going to happen with this version.  thanks.
View Range/Plan Region Visibility Controls in RCP
Wed, Feb 1, 2012 at 11:20:32 AM
plan region - elevation symbols
Mon, Nov 14, 2005 at 2:14:36 PM
Partial Element Visibility
Thu, Sep 3, 2015 at 1:02:29 AM
Sub-region visibility
Mon, Mar 3, 2008 at 11:58:28 AM
Overall Plans and Partial Plans ... looking for Best Practice [ 1 2 ]
Sun, Jul 21, 2019 at 7:44:21 AM
15
Page generation time: 1.1731
