14 Users Online (12 Members):
Forums >> Workflow & Implementation >> Worksets >> Workset-based parameter?
24 Posts No Rating |
I am experimenting with a project where different building types are organized by workset; there's a workset for building type III, IV, V, etc. I want to make a wall takeoff schedule that separates the amount of materials and objects used in each workset. I can't seem to find a way to construct that parameter though. Any tips? Is it possible? If not, these worksets can be later linked into some kind of "master" plan and then sorted by file, right? But will each building type require it's own revit file? Thanks, Kevin DISCLAIMER: This may have already been addressed on this site, and even though I searched for it, if I am in error for posting it then feel free to complain a lot through replies to this thread, rendering your complaints almost completely useless.
Rather than using phases, I think you will have to use a shared parameter assigned to each category element and filter your schedules accordingly.
I see where you're going with this, but it brings about a new problem: my project contains a lot of model groups, which seem to be unable to have any parameters assigned to them. While the groups themselves belong to all worksets, altering an instance parameter for their contents causes changes to the parameters in all groups and consequently all worksets. I think I may have done it wrong.
Revit does demand earlier decesions.... Perhaps seperate projects that are linked.
Visibility/Graphics override based on Workset |
Thu, Jan 19, 2017 at 2:35:04 PM
Can't Edit Workset Parameter |
Thu, Oct 23, 2008 at 11:36:23 AM
Schedule concrete volume (including column, slab & beam) by workset |
Thu, Oct 28, 2010 at 8:04:52 AM
Isolate Wall Types |
Wed, Sep 22, 2004 at 11:39:37 AM
Wall Based Plumbing Fixtures.. Elevation parameter.. help please! |
Thu, Oct 2, 2008 at 12:08:49 PM
