Forums >> Revit Building >> Technical Support >> vanished symbols
Wed, Oct 8, 2008 at 10:59:46 AM | vanished symbols
psemrau
I created a few symbols to represent Exit signs for a life safety sheet.
 Now the weird thing is that sometimes they disappear showing only the ones drawn at a previous session, or disappear completely on the local file that is working on it. They are not hidden or turned off in VV/VG. And it takes us a lot of time to revive them form central or other files.
At other occasion it rotated all symbols back to their original created angle.  I thought they behaved like dumb autocad blocks that would not scale, but seems they have a mind of their own.  Any help on this? Should I switch to families instead?
Thanks
Wed, Oct 8, 2008 at 11:17:15 AM | vanished symbols
Symbols are like text - they will not scale per view.  If your symbol is a 1/8" square when printed, it will be 1/8" in every view - no matter what scale the view is.
Detail elements scale themselves per view scale.
Both symbols and detail elements only reside in the view they were placed in.
Wed, Oct 8, 2008 at 11:24:49 AM | vanished symbols
psemrau
yep, I created those symbols with all that in mind, but why do they disappear randomly?
Wed, Oct 8, 2008 at 11:40:01 AM | vanished symbols
I have never seen that happen so I think the problem is not in the program.
We would need more information in order to help you.  It might help if you put this symbol in a simple dummy project and see how it acts.  You may also have some issues with your system or installed program.
If you want to share the symbol, perhaps soeone can look at it but I doubt there is a problem there.  What are you running?
Wed, Oct 8, 2008 at 11:52:48 AM | vanished symbols
psemrau
Revit 2009 on XP
Here is the symbol if you want to give it a look.
My model info just vanished, when I synched model
Tue, Mar 14, 2023 at 8:29:02 AM
Deleting import symbols
Thu, May 8, 2008 at 3:14:21 PM
symbols, detail components
Mon, Jan 23, 2012 at 6:35:40 AM
SYMBOLS
Fri, Mar 6, 2009 at 11:02:48 AM
Electrical symbols - scaling
Tue, Feb 5, 2013 at 7:18:56 AM
Page generation time: 6.3577
