Forums >> Revit Building >> Technical Support >> Room color fill goes to wall centreline not to finish face of wall
Wed, Oct 8, 2008 at 10:06:46 AM | Room color fill goes to wall centreline not to finish face of wall
peetree21
1 Stars: 1 Votes
i want to change my username
Edited on: Thu, Jun 19, 2014 at 5:11:04 PM
Thu, Oct 9, 2008 at 3:12:35 AM | Room color fill goes to wall centreline not to finish face of wall
tim123
4 Stars: 19 Votes
Is your view set to wireframe?
Thu, Oct 9, 2008 at 3:56:24 AM | Room color fill goes to wall centreline not to finish face of wall
peetree21
1 Stars: 1 Votes
Edited on: Thu, Jun 19, 2014 at 5:11:28 PM
Thu, Oct 9, 2008 at 4:46:26 AM | Room color fill goes to wall centreline not to finish face of wall
tim123
4 Stars: 19 Votes
My colour fills stop at the edge of the wall.  By turning it to wireframe I can get it to meet at the centre.  Is it perhaps the type of measurement - ie gross area totals all space and net area will total useable space?  I have'nt tried this yet but I will give it a quick go.
Thu, Jul 16, 2009 at 3:52:50 PM | Room color fill goes to wall centreline not to finish face of wall
pepsiqueen
pepsiqueen Avatar
has anyone figured this out? i am having the same problem. running revit 2010. using a room color scheme the actual rooms are computer to finish face but when the color scheme is in the foreground, so that is colors the furniture, the color also bleeds to the centerline of the wallks.
I'd rather be riding at whistler. or highland. thats good too.
Mon, Sep 26, 2011 at 4:20:41 PM | Room color fill goes to wall centreline not to finish face of wall
lbrooksher
Me too!  I need to show which rooms are calculating their area based on just that room or are being calculated with some of the walls "non-room bounding".  I have made all of the walls transparent, but.. for some reason... some times it is to the center line of the wall... others interior face.  Anyone know what setting is causing this?
Mon, Sep 26, 2011 at 5:00:49 PM | Room color fill goes to wall centreline not to finish face of wall
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Check out the setting in the Room and Area tab. In there is a setting for how the areas and volumes are calculated
Mon, Sep 26, 2011 at 6:15:13 PM | Room color fill goes to wall centreline not to finish face of wall
lbrooksher
I tried that.  It appears to set it that way for all future room object inserts, but does not change it for room objects already in the model.
Anyway to fix the room objects already in the model?
Mon, Sep 26, 2011 at 6:56:25 PM | Room color fill goes to wall centreline not to finish face of wall
lbrooksher
oops... as soon as a department is assigned... it changes back to wall centerline!  Argh!!!
Thu, Apr 24, 2014 at 7:26:18 AM | Room color fill goes to wall centreline not to finish face of wall
ajaichohan
Set the view to hidden line
Wed, Apr 30, 2014 at 1:12:31 PM | Room color fill goes to wall centreline not to finish face of wall
#11
armstrl
Under the Properties toolbar:
Graphics>Color Scheme Location, make sure this is set to background not foreground
Adding Room Tag Parameters
Tue, Oct 24, 2006 at 10:29:46 AM
Area Plans with Color Fill Through Walls
Thu, Oct 8, 2015 at 6:50:30 AM
Room Schedule: wall finish for each wall in a room
Wed, Dec 19, 2012 at 5:00:38 PM
curtain wall issue...cant get it at centreline
Thu, Feb 9, 2012 at 1:49:36 PM
What is the difference Between Wall Finish Face and Wall Core Face
Fri, Oct 16, 2009 at 10:54:02 AM
Page generation time: 0.9132
