12 Users Online (10 Members):
Forums >> Revit Structure >> Technical Support >> Levels - True v's datum
Can anybody help? I've got my levels in sections set to real contour readings. Is there a way to simply reset them back to a ground floor datum of 0.0m?
Are you using shared coordinates? If you are you can cange the Levels Coordinate between Shared and Project. If not you will have to relocat the project using "Relocate Project". I would set up Shared Coordinates before relocating.
----------------------------------- BallewDesigns.com |
Datum Levels |
Tue, Jul 1, 2008 at 4:18:53 PM
Relative levels |
Mon, Dec 14, 2009 at 2:29:26 PM
Basement Datum Level Line: Now you see it, now you don't |
Fri, Nov 18, 2011 at 11:41:49 AM
Topographical Datum Points |
Wed, Aug 18, 2010 at 11:04:41 AM
Datum Control |
Fri, Apr 21, 2006 at 6:39:23 AM
