Forums >> Revit Building >> Technical Support >> Inventor files
Tue, May 3, 2005 at 6:22:56 PM | Inventor files
revitclass101
Does anyone know how to create a file in inventor and import it into revit?
Thu, Jun 2, 2005 at 6:13:34 PM | RE: Inventor files
BIGMANJEE
if you can export the file to a dwg, dxf, you can import it directly into revit. if this does not work you and you can import it into 3ds max or viz instead than save out as a 3ds. then you can import that 3ds into autocad then save as dwg. then you can import to revit. a bit of a bugger around but gets the job done.
Thu, Jul 13, 2006 at 11:11:17 PM | RE: Inventor files
Cassie
You can import , saving your Inventor file as .SAT and import into Revit as a .SAT file .
Thu, May 10, 2007 at 10:51:39 AM | Inventor files
Murdoc1905
Is There any way to import .sat to Revit 9.0 with the color?
Edited on: Mon, May 14, 2007 at 10:49:48 AM
Inventor files to revit components
Wed, Oct 12, 2011 at 8:38:24 AM
Inventor to Revit Structure 2010 or 2011
Fri, Dec 10, 2010 at 5:45:29 AM
Inventor files into revit
Tue, Jan 22, 2013 at 7:28:04 AM
adsk files from inventor to revit
Thu, Feb 27, 2014 at 7:11:47 AM
creating models in Inventor and exporting them into revit
Sun, Mar 6, 2011 at 4:53:21 AM
Page generation time: 0.8227
