Forums >> Revit Building >> Technical Support >> Design Options and Areas
Mon, Oct 6, 2008 at 6:00:04 PM | Design Options and Areas
SWsam
Hello all,
I have created several design options for different building massings.  Everthing is going great until I try to do area plans.  As I have now found out, areas and area boundaries cannot be placed into design options.  Can anyone provide a solution to how to show areas of different options?  I am considering worksets, but would like some opinions.  I am using revit 2009.
thanks.
SWsam
Tue, Oct 7, 2008 at 7:55:42 AM | Design Options and Areas
The information REVIT gives you under areas and design options is a little confusing.  To do what you want:
  • First, create your base scheme and area plan with areas.
  • Then while in the design option showing your other scheme, go to settings and create a new area scheme for this option.
  • Now create a new area plan using this new scheme.  Do not do an automatic boundary.
  • Now exit your design option and then create your boundary by pointing or drawing your lines and then add your area.
Do this as many times as you need to.
Wed, Oct 8, 2008 at 10:27:36 AM | Design Options and Areas
SWsam
Awesome! Works great.
Thanks WWHub.
SWsam
Wed, Nov 14, 2012 at 10:42:51 AM | Design Options and Areas
dstarr
Hello there! I'm having the same trouble but can't seem to get past the error.  Could somone walk me through this process?  Thanks!
Wed, Nov 14, 2012 at 10:53:19 AM | Design Options and Areas
What error?  The process is described in a post above.
Wed, Nov 14, 2012 at 10:57:06 AM | Design Options and Areas
dstarr
Thanks for the quick reply, but I am getting the "Areas and Area Boundaries are not allowed in Design Options. Make an Area Scheme and an Area Plan for this Option then draw all Areas and Area Boundaries in that view." Error, even though I *think* I followed the above directions.
Wed, Nov 14, 2012 at 11:07:06 AM | Design Options and Areas
dstarr
Would you mind emailing me? I can be reached at dstarr-at-epsteinglobal.com  Thanks!
Sun, May 25, 2014 at 3:55:32 PM | Design Options and Areas
mehsabsa
This is how you can create different color scheme and area plans for each design option in Revit 2014 (possibly same in other versions as well).
1. Create your plan options ( Option1 , Option 2 etc..)
2. Architecture Tab → Room & Area → Area and Volume Computations → Area Schemes → Create New Area Schemes for each option → OK
3. Architecture Tab → Area → Area Plan → Pick desired area plan options from type per floor → OK
4. While on area plan; Click VG (visibility graphics) → Design Options → Change automatic view to desired design option → OK
5. Draw the Area Boundries and locate Areas or Area Tags on that plan.
6. Proporties Tab → Color Scheme → Pick the color scheme that you want
I was confused between color scheme and area scheme after I read previous posts. So, I wanted provide some description.
Hope this helps,
Edited on: Sun, May 25, 2014 at 3:56:07 PM
Edited on: Sun, May 25, 2014 at 4:00:19 PM
Thu, Sep 11, 2014 at 1:10:30 PM | Design Options and Areas
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
This works up until the point where you need to create the color scheme because for some reason this is not possible! Please Help!
http://www.revitcity.com/forums.php?action=viewthread&thread_id=33642
Area Plans for design options
Fri, Jul 21, 2017 at 1:37:36 PM
I need to show two interior design options for the same floor. Any ideas?
Wed, May 5, 2010 at 1:22:01 PM
Design options issues
Thu, Mar 2, 2006 at 10:35:31 AM
Design Options
Wed, Dec 24, 2003 at 10:33:51 AM
Titleblocks & Design Options
Mon, Dec 8, 2008 at 2:06:33 PM
Page generation time: 0.2362
