Forums >> Revit Building >> Technical Support >> Reference Plane/Instance Parameter in Family
Mon, Oct 6, 2008 at 1:57:57 PM | Reference Plane/Instance Parameter in Family
bradleymatthew
Revit 09
I've created a family which contains objects that are controlled by Yes/No visibility parameters, and that are attached to reference planes.  I have set instance (dimensional) parameters to the reference planes so that when imported into the project the blue arrows show up and allow you to adjust as needed.  That all works great....the problem being that whenever i turn one of those objects off (via the Yes/No visibility parameter) the blue arrows still remain from the reference plane/instance parameters.  Has anyone developed a clever work around so that the arrows, and ultimately the reference planes turn off with the object?
Bradley
Mon, Oct 6, 2008 at 2:00:46 PM | Reference Plane/Instance Parameter in Family
I don't believe you can turn off the reference planes and thus.... the instance dimension label will still show.
Mon, Oct 6, 2008 at 2:06:52 PM | Reference Plane/Instance Parameter in Family
robinballew
robinballew Avatar
3 Stars: 4 Votes
Don't think you can do anything about the controll nodes.. You can add a Visibility ON/OFF controll to Referance Lines, not planes, but I don't think that will do much for the controll nodes either.
BallewDesigns.com
Mon, Oct 6, 2008 at 2:20:02 PM | Reference Plane/Instance Parameter in Family
bradleymatthew
That's pretty much what i though - is there a better way that i should do this so that i still have the benefits of the control nodes, but not have the nuisance of the control nodes?
Bradley
Mon, Oct 6, 2008 at 2:31:46 PM | Reference Plane/Instance Parameter in Family
robinballew
robinballew Avatar
3 Stars: 4 Votes
If the parameter is not "instance" you will not get the controll node. Post the Item for Review.
BallewDesigns.com
Instance Parameter for Variable offset from Ref Level Not behaving Window Fam
Wed, Nov 5, 2014 at 4:15:32 PM
Snap using instance parameter grip
Thu, Mar 5, 2009 at 11:04:47 AM
Instance Parameter help - grips make family move
Sun, Dec 7, 2014 at 8:12:03 PM
Reference to nested family
Wed, Sep 21, 2022 at 7:49:43 AM
Trouble with Array Parameter within a nested family
Wed, Sep 12, 2012 at 5:19:16 AM
Page generation time: 2.0509
