Forums >> Revit Building >> Technical Support >> Host wall thickness, in door schedule.
Mon, Oct 6, 2008 at 10:13:44 AM | Host wall thickness, in door schedule.
Revboy
I am using Revit Architecture 2009
I have a door schedule with well over 700 internal doors, and I am trying to schedule off the host wall thickness.
Ive tried creating an instance paramiter and constraining this to the wall (host front and back faces), this seems to work, until loaded into the project. The paramiter remains at the default and does not update depending on the host wall type.
Anyone know how to referance the host wall thickness in a door family or a suitable work-around?
Edited on: Mon, Oct 6, 2008 at 10:19:10 AM
Mon, Oct 6, 2008 at 10:17:18 AM | Host wall thickness, in door schedule.
You can't.  I believe this is on the wish list.  You will have to add a shared parameter - instance.... and fill it in.
Mon, Oct 6, 2008 at 10:22:31 AM | Host wall thickness, in door schedule.
Revboy
Thiought so, thanks for the quick response, Its been tweaking my nipples all day.
I suppose id better get a coffee and get started.
Wed, Feb 10, 2010 at 3:02:33 PM | Host wall thickness, in door schedule.
Luigiman
Hi, has this changed in Revit 2010? I need my window and door schedule to show the "host" type . Any suggestions?? Thanks
Wed, Feb 10, 2010 at 3:09:18 PM | Host wall thickness, in door schedule.
Same answer as last time.
Wed, Mar 3, 2010 at 3:26:52 PM | Host wall thickness, in door schedule.
Luigiman
Thanks...
Thu, Mar 4, 2010 at 12:19:14 PM | Host wall thickness, in door schedule.
TomDorner
4.5 Stars: 25 Votes
In a round-about way it is possible, just not inside of Revit itself.
If you export to ODBC, each door knows its host ID.  Each Host know its thickness (in meters as all ODBC measurements are in meters) Therefore you could construct a report or query that shows the host wall thickness in a door schedule, just not live inside of Revit.
The obvious question: Why can't I just do it inside of Revit?
Answer: Beats me.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Thu, Mar 4, 2010 at 2:37:26 PM | Host wall thickness, in door schedule.
Luigiman
jejeje, true... Thanks
Mon, Nov 7, 2011 at 4:40:30 AM | Host wall thickness, in door schedule.
buttonsrtoys
1 Stars: 1 Votes
I'm trying to do something similar with 2012, only the wall type would be sufficient -- I don't need the thickness. Is this possible?
Mon, Nov 7, 2011 at 7:36:34 AM | Host wall thickness, in door schedule.
We now have reporting parameters but here are the limitations:
A reporting parameter is a parameter type that has its value driven by a particular dimension in the family model. Reporting parameters extract a value from a geometric condition and use it to report the data to a formula or as a schedulable parameter.
Length, radius, angle, and arc length are available as reporting parameters. (Arc length can be only labeled as a reporting parameter).
Fri, May 31, 2019 at 4:26:18 AM | Host wall thickness, in door schedule.
#11
koleman
So this means i can not report the host "Wall Type" Parameter. Right?
Door Family - wall thickness parameter!!
Thu, May 14, 2009 at 10:19:48 AM
Host Wall type in Door schedule
Fri, May 31, 2019 at 6:07:58 AM
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Curtain Wall Door Head Heights Not Displaying in Door Schedule
Thu, Aug 25, 2011 at 2:24:12 PM
from/to room data in door schedule of a host model
Fri, May 15, 2020 at 10:47:42 AM
Page generation time: 0.9762
