Forums >> Revit Structure >> Technical Support >> {3D} view set to "Shading with Edges" looks like "Wireframe" with color...
Mon, Oct 6, 2008 at 8:16:05 AM | {3D} view set to "Shading with Edges" looks like "Wireframe" with color...
justabill
I have a fairly complicated project (280,000+ SF, multiple floors, multiple phases, two linked files), and everything is fine except...  in all of my {3D} views set to "SwE" the edges of interior walls show up where they meet exterior walls and roofs.  All of the edges of the staircases show up as well, and all of the windows display as if the view was set to "Wireframe".
 It is like this for the main model (220,000 SF) as well as the linked model (60,000 SF).  The Site is also linked.
 Any ideas why this is happening?
Mon, Oct 6, 2008 at 8:24:06 AM | {3D} view set to "Shading with Edges" looks like "Wireframe" with color...
2009 ?
Mon, Oct 6, 2008 at 8:25:25 AM | {3D} view set to "Shading with Edges" looks like "Wireframe" with color...
robinballew
robinballew Avatar
3 Stars: 4 Votes
A few things you can check.
1. Does it do it all the time. If you first open the file for the day is it ok and then it gets bad?
2. How does it print? Same or is it correct.
3. Does it happen to all users? Or just your computer. If you are the only user try it on some other systems.
4. Are you running dual monitors?
Try turning off Open GL if it is on.
I would guess that it is your graphics card.
Happens ocassionaly on my system with very large complex models..
BallewDesigns.com
Mon, Oct 6, 2008 at 8:44:13 AM | {3D} view set to "Shading with Edges" looks like "Wireframe" with color...
justabill
Thanks,
 Yes, it is 2009 on a 64 bit station.
 It happens all of the time and at every station that opens it.  I am running on a single monitor, but it also happens at stations with two monitors.  It prints that way as well.
 Turn off Open GL?  What is that, and where and how?
 I'll upload some images to photobucket or something.
Mon, Oct 6, 2008 at 8:49:42 AM | {3D} view set to "Shading with Edges" looks like "Wireframe" with color...
justabill
http://i120.photobucket.com/albums/o191/justabillwilliam/3D.jpg
http://i120.photobucket.com/albums/o191/justabillwilliam/3Ddetail.jpg
Edited on: Mon, Oct 6, 2008 at 9:00:45 AM
Mon, Oct 6, 2008 at 9:00:13 AM | {3D} view set to "Shading with Edges" looks like "Wireframe" with color...
4 Stars: 205 Votes
OPENGL= go to Top menu>Settings>Options, there are a Box where you can Enable/Disable this option, there are here some threads with this issue and I THINK Robin has right, i have a ATI X1600 512Mb and I NEVER had this problem and there guys here who have this problem and have Nvidia's and Gforce's, so i think this is a problem Revit/Graphics card... try this, delete 3D view and create a new one, the problem is solved (by now).
Mon, Oct 6, 2008 at 9:08:54 AM | {3D} view set to "Shading with Edges" looks like "Wireframe" with color...
justabill
That did it.  Thanks Typhoon!  I looked for threads on this, but didn't see any.  Haven't posted here before though so probably just didn't know where to look.
 I'd been asking our guru about this for about a month...  this was a lot faster.  :D
(Open GL was not turned on btw.)
Mon, Nov 24, 2008 at 4:21:00 AM | {3D} view set to "Shading with Edges" looks like "Wireframe" with color...
orangezach09
Thanks so much!  This problem has been plaguing me for days...deleting the 3D view works!  I appreciate ya'lls help.
zach
Thu, Dec 4, 2008 at 2:41:37 AM | {3D} view set to "Shading with Edges" looks like "Wireframe" with color...
KOM6U
Typhoon -... try this, delete 3D view and create a new one, the problem is solved (by now). !!!
Typhoon! YOU ARE THE MAN !!!
Wed, Dec 10, 2008 at 3:46:55 AM | {3D} view set to "Shading with Edges" looks like "Wireframe" with color...
SMR3
Just wanted to add, that I had also such problem, but then I just pressed Home button in 3D view, and everything was ok again, and no need for deleting the 3d view...
Wed, Aug 12, 2009 at 4:16:40 AM | {3D} view set to "Shading with Edges" looks like "Wireframe" with color...
#11
ElvisDDA
I have the same problem here, it's on all our computers with different graphics cards and Open GL is not enabled on any of them.  The view is showing as wireframe no matter what I select.
Wed, Aug 12, 2009 at 7:05:45 AM | {3D} view set to "Shading with Edges" looks like "Wireframe" with color...
#12
Did you do as Typhoon suggested? ... try this, delete 3D view and create a new one !!!
See Through "Shading With Edges" In 3D... then Crash
Thu, Oct 30, 2008 at 11:05:38 AM
11
Problems plotting "shading with edges"..................
Mon, Mar 24, 2008 at 8:01:09 AM
::--:: Roof Plan in Wireframe ::--::
Wed, Mar 29, 2006 at 11:26:00 AM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
shading with edges, side in shadow comes out white
Fri, Dec 14, 2007 at 11:12:55 AM
Page generation time: 1.9942
