Forums >> Revit Building >> Technical Support >> Curved Window/Bent Glass
Mon, Oct 6, 2008 at 5:58:40 AM | Curved Window/Bent Glass
rkarch
1 Stars: 1 Votes
I have been looking in many libraries and searching forums but cannot seem to find any families or information on where to get/or how to do a curved window with curved glass? (see attached image)
I am hoping there is a family available that you could install into a curved wall...
Any help is much appreciated.
Mon, Oct 6, 2008 at 6:06:56 AM | Curved Window/Bent Glass
There is a curved double hung in the dowload area : http://www.revitcity.com/downloads.php?action=view&object_id=2384
You might want to look at that to see how they did it.
Mon, Oct 6, 2008 at 2:20:22 PM | Curved Window/Bent Glass
phxchristian
You may want to do a curtain wall or draw a curve first and then use the select wall by line command, you may even be able to do that with a window.  (Create a wall type that is 1" Glazed or something like that)
 -Christian Jesperson
Gensler Phoenix
Mon, Oct 6, 2008 at 2:45:58 PM | Curved Window/Bent Glass
4 Stars: 205 Votes
Hi, use curtain wall panel, see the images attached, I also put the Family of "Curved Panel", you can edit and create new types and use for what you need...
Curved wall and curved window
Tue, Jun 23, 2015 at 8:23:19 AM
curved window (this time with attach)
Fri, Nov 11, 2005 at 9:39:56 AM
Curved window
Thu, Nov 10, 2005 at 12:25:03 PM
Curved Angled Glass Walls
Thu, Jan 20, 2011 at 3:01:49 PM
Need help adding glass to a window I downloaded.
Wed, Sep 26, 2012 at 11:11:48 AM
Page generation time: 0.3306
