Forums >> Revit Building >> Technical Support >> To hide sheets from drawing list?
Mon, Oct 6, 2008 at 3:34:20 AM | To hide sheets from drawing list?
jjtan58
hi guys, I'm creating a drawing list, but there are some drawings I dont want to show. Can I hide them some how? Thanx a lot Smile
Mon, Oct 6, 2008 at 5:53:52 AM | To hide sheets from drawing list?
Like many questions in REVIT, a simple search in your help would answer this question.  Look at "drawing list".
Mon, Oct 6, 2008 at 6:32:46 AM | To hide sheets from drawing list?
jjtan58
hi, i found it, but what should i do, if i want to show drawing 100 on list A but not list B???
To omit a sheet from a drawing list
  1. In the Project Browser, right-click the name of the sheet to omit, and click Properties.
  2. On the Element Properties dialog, clear Appears In Drawing List.
    This option is selected for all sheets by default.
  3. Click OK.
Mon, Oct 6, 2008 at 6:47:40 AM | To hide sheets from drawing list?
Create a new shared parameter - assigned to sheets.  Then use that as a filter in your drawing list.  Might name it  Project phase....
Here is another learning opportunity for you - shared parameters - look it up in the help.
Edited on: Mon, Oct 6, 2008 at 6:48:19 AM
Mon, Oct 6, 2008 at 7:12:12 AM | To hide sheets from drawing list?
BTW - If your sheet numbers have a prefix like SD then you can filter to exclude those sheets that start with SD.
And in another schedule filter for those not containg SD.
Edited on: Mon, Oct 6, 2008 at 7:13:04 AM
Mon, Oct 6, 2008 at 8:41:18 AM | To hide sheets from drawing list?
jjtan58
OMG! it works! the filter thing is smart! thanks a lot for help!! Smile
Thu, Sep 14, 2017 at 1:13:51 PM | To hide sheets from drawing list?
KARTINI
What if you do not have a sheet but you added some drawings into the Index. How do you hide those?
new sheets - don't want them in my "drawing list" schedule
Fri, Jan 16, 2009 at 2:43:17 PM
Revit Drawing List
Tue, Mar 15, 2011 at 5:20:07 PM
Drawing List's
Wed, May 26, 2010 at 11:49:42 AM
Sheets showing in Architectural Drawing list but not in project browsers?
Wed, Jan 11, 2012 at 8:08:35 AM
Drawing list sheets are in incorrect order
Fri, Jul 9, 2010 at 10:59:05 AM
Page generation time: 0.4002
