26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Revit intu 3DSMax
7 Posts No Rating |
Please,
I am using 3ds max instead of Viz. Can I link the revit files to Max like to viz. I dont want to have istalled Viz and Max only because of transfering the files from revit to viz and than to max.
Thank you
I believe the addon for viz also works with max... But don't quote me on that as i haven't tried it.
1 Posts No Rating |
I just upgraded to revit 8 and downloaded the plugin for viz 2005...how do you use it....where is it in revit.
The plugin is for viz not revit...
Just export out a 3D Dwg out of revit and providing the plugin is installed in viz it will be able to interpret all the accurender material settings that were previously setup in revit.
Saving to 3dsMax? |
Mon, Jul 10, 2006 at 3:03:49 PM
Linking Revit to 3dsmax 9 sp1 |
Tue, Jun 26, 2007 at 11:05:38 AM
Revit to 3dsMax for GPU utilization |
Fri, Dec 21, 2012 at 12:12:35 PM
revit file too heavy when importing into 3dsmax |
Fri, Sep 11, 2009 at 1:13:54 PM
how to transform my 3d from 3dsmax into technical drawing |
Mon, Jan 19, 2009 at 1:32:51 PM
