Forums >> Revit Systems >> Technical Support >> Flip Controls
Fri, Oct 3, 2008 at 3:50:41 PM | Flip Controls
strauss
Are there no Flip Controls that will mirror an object about a horizontal axis? (ie. I am working in an elevation view and want the ability to mirror about the main Reference Plain) It doesn't seem right that the controls would only apply in two dimensions.
Fri, Oct 3, 2008 at 4:42:38 PM | Flip Controls
robinballew
robinballew Avatar
3 Stars: 4 Votes
Not sure what you are talking about. Is it a family "flip" controll. If so you can flip it in both directions.
BallewDesigns.com
Fri, Oct 3, 2008 at 5:01:39 PM | Flip Controls
4 Stars: 205 Votes
No, you only has the "Control" button in a family in a "Plan View", in "Elevation or Section" the Control Button isn't allowed...
Fri, Oct 3, 2008 at 5:16:03 PM | Flip Controls
robinballew
robinballew Avatar
3 Stars: 4 Votes
That is true that you can't see the flip controll in elevation but it still works. Just right click and you still get the option to flip hand or flip face..Like in windows and doors..
BallewDesigns.com
Mon, Oct 6, 2008 at 7:20:41 AM | Flip Controls
strauss
Right clicking to flip hand or flip facing is just fine... if you are in the family editor. It, however, is useless in a project. Yeah, I could just make seperate families that handle each instance, but that completely defeats the purpose of what I am trying to do. A vertical flip control is definitely on my wishlist- that, and the ability to add an obliquing angle to dimensions so they don't look like curse in 3d views.
Mon, Oct 20, 2008 at 10:43:50 AM | Flip Controls
KevinKernaghan
It's kind of a lengthy workaround, but you could mirror across the axis you want in the family editor and then apply the same dimension control parameters to each half.  Then you could add a yes/no visibility control to each side...it wouldn't be as user-friendly as a flip control but you could still switch sides pretty easily in a model without having to load 4 families.
Flip Controls in Nested Families
Wed, Jan 16, 2008 at 1:47:48 PM
Flip Control
Thu, Aug 11, 2005 at 7:11:42 PM
Adding a Flip Control
Mon, Dec 5, 2011 at 5:12:51 AM
Flip Control on Profiles
Mon, Jul 9, 2018 at 9:25:14 PM
building controls
Wed, Feb 3, 2010 at 8:26:27 AM
Page generation time: 0.0328
