Forums >> Revit Building >> Technical Support >> Topography: importing CVS only created single line
Fri, Oct 3, 2008 at 8:36:51 AM | Topography: importing CVS only created single line
siwilks200
i have a dxf with 3d points 85,918 in total - i cant make a toposurface using revit! i have extracted the point data from the dxf file into a cvs file that revit recognises, however revit reproduces it as a single line only with no topography - see attached. why is this? the cvs has all the relevant data. thanks
Fri, Oct 3, 2008 at 9:09:44 AM | Topography: importing CVS only created single line
4 Stars: 205 Votes
Hi, forgot to attached the screenshots...
Fri, Oct 3, 2008 at 9:13:56 AM | Topography: importing CVS only created single line
siwilks200
Hi, revit will not show me anything now, so there will be nothing to see ! but i have now attached the 3d data as a text file - it appears just like this in the CVS file
Fri, Oct 3, 2008 at 9:22:43 AM | Topography: importing CVS only created single line
siwilks200
apologies . was over file size limit, here it an example of the 3D data
Fri, Oct 3, 2008 at 2:34:24 PM | Topography: importing CVS only created single line
4 Stars: 205 Votes
Hi, did you check this in Help menu? did you see the file?
Fri, Oct 3, 2008 at 2:52:56 PM | Topography: importing CVS only created single line
Typhoon's post seems to make the problem perfectly clear and also points out why the original poster should learn to use his help file.  Many problems can be averted.
Mon, Oct 6, 2008 at 4:49:38 AM | Topography: importing CVS only created single line
siwilks200
Hi. The help file was obviously the first thing i looked at and it seems i am following it accordingly. The 3D data text file i uploaded is an example of the data i extracted (using AutoCAD Data Extraction) and seems to contain the required info that is referred to in the help file (X,Y,Z). The import>points file recognises and uses both the CVS and txt files i created but it doesnt display the land. First it offers me 2 warnings (see attached) then when i click on 3D it only shows a single line (see attached) with the elevation being the same for each of the points. I have also attached an example of what the CVS file looks like - just like the txt. The only thing i am doing different i can see is not having the x,y,z coords as "the first numerical values in the file" as per the help file. Thanks in advance
Mon, Oct 6, 2008 at 5:45:10 AM | Topography: importing CVS only created single line
4 Stars: 205 Votes
Hi again, look at your image file points and the Help image, "they" said: "ANY ADDITIONAL NUMERIC INFORMATION FOR A POINT MUST OCCUR AFTER THE X,Y AND Z COORDINATE VALUES" in your file in column "A" I see numbers (1).
"They" said: "THE FILE MUST ALSO BE IN A COMMA-DELIMITED FILE FORMAT..." You have points ".", i don't know if this is the problem with your file but i think so,  "Some rows from the file could not be used" - this warning i think it's the "First and Last" ROWS, delete them, also delete Column "A-B", you don't need them, also, check the 4 image you post with the "Line", did you see in the "Options Bar" the Value of "Elevation"? what Units are you working? By your 3 image your Z=METERS, that elevation in the line is: 221960000.0m???
Mon, Oct 6, 2008 at 6:32:05 AM | Topography: importing CVS only created single line
siwilks200
Hi. I managed to sort it out earlier today but many thanks to you Typhoon. One problem was the CAD file itself and the other was the data extraction method.........FIRSTLY I obtained the 3D point file from PROMAP (online company) and it was provided with the X&Y values extremely high compared to the Z (re: the first warning), so i moved the bottom left corner to 0,0 (to make the X,Y,Z look more like 5,5,20 compared to the original 38200,29500,20)......and SECONDLY you were right Typhoon, while extracting the data i had to make sure i was only extracting the XYZ data (using AutoCAD data extraction check boxes) and not the name and count columns. Cheers
Mon, Oct 6, 2008 at 8:31:55 AM | Topography: importing CVS only created single line
4 Stars: 205 Votes
You Welcome, next time you KNOW what to do and you don't need to come here and ask anymore....
Mon, Oct 6, 2008 at 8:38:16 AM | Topography: importing CVS only created single line
#11
siwilks200
charming
importing Topography
Mon, Jun 5, 2006 at 8:19:07 AM
A Whole Lot of TOPOGRAPHY & CONTOUR LINE questions...
Tue, Nov 22, 2011 at 6:07:37 AM
Revit Topography doesnt follow CAD import
Wed, May 25, 2011 at 11:38:26 AM
Importing site plan to do a 3D topography
Sun, Jan 29, 2006 at 11:53:50 PM
Giving topography thickness when rendering
Thu, Jan 22, 2009 at 9:42:06 AM
Page generation time: 0.5522
