Forums >> Revit Systems >> Technical Support >> Schedules: Ie Door schedules!
Fri, Oct 3, 2008 at 2:48:23 AM | Schedules: Ie Door schedules!
missr
I am having difficulty with schedules. I have manageds to create the schedule for all the doors, and add info etc. But when it comes to presenting the info how my office normally does im having a problem manipukating the schedules. How it is normally done in our office, is an A4 sheet, with a plan and elevation of the door item (that is fine, done!) and then below it the information of THAT particular door. Is there a way to split up the schedule, the rows? the be able to show one row on a sheet?
ANY SUggestion?s!
Fri, Oct 3, 2008 at 4:32:30 AM | Schedules: Ie Door schedules!
Dafpfy
3.5 Stars: 11 Votes
i dont think thats possible, but if you can tag your door, you could make a doortag with the info you want.
dont know if that will work but you can try Smile
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Fri, Oct 3, 2008 at 5:57:41 AM | Schedules: Ie Door schedules!
KingRevit
4 Stars: 12 Votes
the way dafpfy says is the best if you use shared paramaters you can then add all the info you need into a custom tag. it might take a while to set up initially but then in everyother project its easy, just need to remember to make your paramaters in the famlies to be shared.
Fri, Jul 11, 2014 at 2:58:22 PM | Schedules: Ie Door schedules!
poblivion
Use the schedule as a SCHEDULE, and refer to the CODE TYPE of the door to the description on a DOOR LEGEND, which is what your particular A4 sheet is.
multiple schedules
Tue, May 1, 2012 at 1:04:42 PM
window and door schedules
Wed, Apr 14, 2010 at 5:23:52 AM
Schedules for Information In Schedules HAHA
Mon, Feb 13, 2012 at 12:08:12 PM
Schedules
Wed, Jun 2, 2010 at 10:04:37 PM
Schedules on multiple sheets
Thu, Apr 27, 2006 at 11:01:59 PM
Page generation time: 2.9772
