Forums >> Revit Building >> Tips & Tricks >> Image over Topo Surface
Thu, Oct 2, 2008 at 11:46:51 AM | Image over Topo Surface
michael91077
4.5 Stars: 2 Votes
Does anyone know if in Revit 2009 it is possible to drape an image over a topo surface, so that it conforms to the surface, like you can do in Sketch-Up. Any help with this would be appreciated. Thanks.
Thu, Oct 2, 2008 at 6:51:11 PM | Image over Topo Surface
robinballew
robinballew Avatar
3 Stars: 4 Votes
you could do it when rendered... Not like sketch up..
BallewDesigns.com
Thu, Oct 2, 2008 at 7:56:15 PM | Image over Topo Surface
michael91077
4.5 Stars: 2 Votes
We might have to try that. what we tried was using the aerial image as a material, and then applying it to the surface, but for whatever reason, the image was mirrored and rotated when applied, and we couldnt figure out how to stop that from happening. i think at this stage in our project. we can use Sketch-up for the site renderings that we need to have done.
Creating Topo using an image
Mon, Feb 21, 2011 at 2:18:32 PM
Surface pattern to Topo surface
Mon, Aug 19, 2013 at 10:50:10 PM
Hole in my topo surface
Thu, Nov 8, 2012 at 8:36:26 AM
11
Deleted Topo Surface
Fri, Apr 2, 2010 at 3:54:58 PM
Topo Surface from autocad into revit
Tue, Oct 13, 2009 at 10:37:25 PM
Page generation time: 4.0450
