Forums >> Revit Building >> Technical Support >> Paramater - # of Track Heads per Fixture
Thu, Oct 2, 2008 at 10:10:57 AM | Paramater - # of Track Heads per Fixture
bradleymatthew
I'm creating a track light fixture with adjustable lights - the trick is that I'm not arraying because i want to be able to adjust their # and placement separately.  I'm setting instance parameters for the dimensions between the heads so that i can place them wherever i want on the track (I'm also adding a rotation parameter so i can rotate the head to any angle i want, and visibility Yes/No parameters for quantities....).
I want to be able to generate a schedule that itemizes each track fixture and the quantity of heads per fixture (which I can't seem to come up with without using the array command...) - For instance track fixture Type F1 has 5 heads, Type F2 has 2 heads, etc......suggestions?
 The problem i keep running into is that I create a Light Fixture schedule and it shows all of the fixtures separately on their own row - total # of heads globally.  I'm sure i can find a family already uploaded that can do this, but i really want to figure it out regardless....
Fri, Oct 3, 2008 at 12:02:10 PM | Paramater - # of Track Heads per Fixture
KKERRIDGE
KKERRIDGE Avatar
2.5 Stars: 3 Votes
why not make a "family type" for each type of track fixture (F1, F2 etc) with a common "text parameter" that has the number of heads preset in the family, and the visibility preset to the number of heads. Once sceduled you should be able to make a formula that adds them all up in your schedule. Make all these type parameters and all the user has to do is select the fixture type.
Your rotation parameter sounds cool too, I hope you post it.
Fri, Oct 3, 2008 at 4:10:36 PM | Parameter - # of Track Heads per Fixture
bradleymatthew
I was thinking along the same lines as far as the family types goes - I'll give the text parameter a go and see what I can come up with (I'll definately post if i can get it working properly... Smile
Thanks for the feedback.
Bradley
Formulas, arrays and track lighting
Thu, May 14, 2015 at 8:31:48 PM
indoor upstair track
Fri, May 10, 2013 at 7:40:14 PM
Running track
Wed, Apr 3, 2013 at 4:43:57 PM
Section heads - (Revit 2010)
Mon, Nov 16, 2009 at 12:48:38 PM
Section Heads
Sat, Jun 10, 2006 at 9:49:47 PM
Page generation time: 0.4529
