Forums >> Revit Structure >> Technical Support >> spot elevation modification
Thu, Oct 2, 2008 at 10:10:08 AM | spot elevation modification
SHATCHER
I need help with creating a spot elevation I can use in sections. I have modified the Level Head to what I want but I would also like to have use a spot elevation where levels have not created. The attachment shows the Level Head that I have modified. I would like the spot elevation to look the same. Can this be done using a spot elevation?
Thu, Oct 2, 2008 at 7:10:52 PM | spot elevation modification
robinballew
robinballew Avatar
3 Stars: 4 Votes
I think you can.. You need to change the "Text Orientation Parameter" to "Vertical" and I think you will have to just type in the text. It looks like you figured out how to adjust the spot elevation family so just add a line to seperate the text from the elevation number.
BallewDesigns.com
Spot Elevation vs. Level elevation
Tue, Aug 19, 2025 at 1:06:15 AM
Invert Elevation Vs. Spot Elevation
Mon, Apr 20, 2015 at 2:09:11 PM
Spot Elevation without Target
Fri, Mar 20, 2009 at 4:57:55 PM
Spot elevation tag issue
Mon, Jun 3, 2019 at 3:18:37 PM
Spot Elevation
Thu, Apr 28, 2011 at 3:46:55 PM
Page generation time: 1.0745
