Forums >> Revit Building >> Technical Support >> Custom stairs mess.
Wed, Oct 1, 2008 at 4:02:17 PM | Custom stairs mess.
timOthyj
4.5 Stars: 14 Votes
Hey..
I am trying to create custom stairs that have M-Miscellaneous Wide Flange for the stringers..
Now I went into new>family>rails to create false rails and move the stringers down to create the ones I needed but when I try to load the new family into my project it cant create it.
What am I doing wrong?
Wed, Oct 1, 2008 at 4:09:16 PM | Custom stairs mess.
timOthyj
4.5 Stars: 14 Votes
***let me show you a image of what I want to create****
And load up the beam that I want to use..
Wed, Oct 1, 2008 at 9:45:26 PM | Custom stairs mess.
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The family you need load should be a profile family and then add it to your rails in your railing setup.  This is a beam family and is not really of any use.
Regards,
Chris.
Wed, Oct 1, 2008 at 10:31:22 PM | Custom stairs mess.
timOthyj
4.5 Stars: 14 Votes
Okay..Then how would I create metal beam stringers??
IS there a simple way around this?
Thu, Oct 2, 2008 at 12:41:47 AM | Custom stairs mess.
timOthyj
4.5 Stars: 14 Votes
SO I kinda figured it out..But I run into the problem of the lower stairs showing thru.
And can I remove the ballisters?
revit not drawing complete custom 3d stairs
Sat, Oct 3, 2015 at 4:17:54 PM
cantilevered stone stairs
Thu, Feb 22, 2018 at 2:30:39 PM
Creating Custom Stairs From Scratch
Thu, Oct 30, 2008 at 1:55:49 PM
Surface pattern on stairs
Mon, Mar 29, 2010 at 6:47:25 AM
Stairs Specialist
Thu, Jul 14, 2011 at 4:51:29 PM
Page generation time: 0.5211
