24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> A serious error has occurred. It is strongly recommended that you use Save As to
I'm using Revit Architecture 2009. When I want to crop a view of one floor plan the error in the attachment appears, but there's no problem with cropping other floor plans in this file. So I made a duplicate of the plan but the same error keeps popping up. Cropping the view by using the view properties won't work either. Does someone have a solution for this problem?
Does someone have an idea, because I have the same error now when I want to copy paste a component in this project. greetings
5 Posts No Rating |
I had that problem last week using Revit MEP 2009. They released a new service pack that same day and it seems to fix the problem. That being said, it may not have been released for all versions of the program.
Difficult to say what the problem might be, have you tried the following: Perhaps obvious, but did you save the file as something else as Revit suggested? Try creating a new floor plan, not duplicating it. With your second thread, does this happen with all components that you paste into the drawing, or a particular one? Was that same component pasted into the plan previously, or into other plans? - Perhaps the component is dodgy. Try saving it and inserting it as a family rather than copying and pasting into your plan.
5 Posts No Rating |
I know that this doesn't help too much, but my problem occured when I would click on certain pipe fittings or try to connect components into other pipe runs. It didn't make any difference if I changed anything at all: Revit would crash when I clicked on those fittings. The only thing that worked for me was the patch that was released last week.
Perhaps it is a similar problem - fredc83 have you tried installing the latest Architectural patch?
A Serious Error [ 1 2 ] |
Thu, Jul 26, 2007 at 11:41:07 AM
21
Stair Command |
Wed, Aug 31, 2016 at 3:32:54 PM
Inserting RPCs Error |
Tue, Dec 14, 2010 at 11:36:50 PM
Error Creating Doors. CANNOT place doors! HELP! |
Wed, Dec 17, 2008 at 1:10:10 PM
Crashing Section Views |
Fri, Jun 1, 2007 at 10:11:33 AM
