Forums >> Revit Structure >> Technical Support >> Beam systems question
Tue, Sep 30, 2008 at 1:11:15 PM | Beam systems question
Jurrien
Hello all.....New to the Revit world here, so I'm still learning. Anyone's help would be greatly appreciated. I'm running into a couple problems in the project I'm working on in Revit Structure 2009. I'm using a linked model and trying to implement multiple beam systems of bar joists for the roof system. For some reason, I cannot get the beam systems to slope. I can get individual beams to slope.  I can get the entire system to change elevations as a group, but cannot get the entire beam systems to slope. I realize that if I had the walls from the central model as well as the bearing points, it should in theory, snap to the bearing points and automatically slope. The problem is that I don't have all of the information from the central model. Is there any way to manually tell the beam system the high points and low points of the slope? Also, I can't seem to get the tags to show up in plan view. I've tried everything I can think of and all I get is a "?" for each member. Any ideas why? Thanks in advance!!!
Tue, Sep 30, 2008 at 2:23:42 PM | Beam systems question
TJKENNEDY
3 Stars: 2 Votes
I have been using named reference planes for all my roof slopes.
Sloped Beam Systems Q's
Mon, Nov 14, 2016 at 11:48:46 AM
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:16 AM
Beam Systems
Wed, Aug 13, 2008 at 11:42:00 AM
Sloped Beam Systems in Revit Structure 2009 question
Thu, Sep 25, 2008 at 11:28:57 AM
Beam Systems
Wed, Feb 8, 2006 at 2:00:42 AM
Page generation time: 0.2518
