Forums >> Revit Building >> Technical Support >> Structural Beams
Sat, Apr 30, 2005 at 10:58:59 AM | Structural Beams
deh1966
I have created structural beams in plan, they show up in 3D view and plan but not in the elevations ( all I can see is a single line at the center, but not the whole profile) I think I have all the right layers turned on. Any thoughts???
Sun, May 1, 2005 at 11:06:38 AM | RE: Structural Beams
rbruins
Try changing de detail level from coarse to medium, that did the trick for me
Mon, May 2, 2005 at 1:15:37 AM | RE: Structural Beams
Arnel Aguel
That is the intended behavior of structural beams and colums to facilitate interoperability with other structural analysis and design programs as they need to export the structural framing as stick diagram for anlaysis purposes. That is why in revit you have the option to change your display representation by changing the detail level to coarse, medium and fine.
Wooden Beams, beams beams.
Wed, Jul 15, 2009 at 12:20:06 PM
Joining Beams and Floors - Beams in a Structural Linked File
Fri, Jun 22, 2018 at 10:07:04 AM
structural concrete beams into wall
Wed, Aug 18, 2010 at 2:02:56 PM
Joining angled structural beams
Mon, Aug 27, 2007 at 5:16:02 PM
Concrete Columns and Beams cuts through wall...
Mon, Feb 4, 2013 at 8:10:15 AM
Page generation time: 0.1218
