Forums >> Revit Building >> Technical Support >> Reference View Tags not referencing actual detail number
Tue, Sep 30, 2008 at 9:58:20 AM | Reference View Tags not referencing actual detail number
clinard
How do I change the Referenced View tags to reference the actual detail and not just the sheet there on. Instead of "Sim" I want that to reference the actual detail number which is detail "1"
 Revit 9 Latest Build
Tue, Sep 30, 2008 at 10:04:34 AM | Reference View Tags not referencing actual detail number
clinard
Referencing an interior elevation to a "detail view" is the only way the get the curse thing to reference the actual detail number. I want to create multiple interior elevation tags that reference an interior elevation. Am I gonna have to draw all my interior elevations with "detail views" just to make it work?
Tue, Sep 30, 2008 at 1:07:15 PM | Reference View Tags not referencing actual detail number
After chosing what view you want to create, click on reference other view and select the view from the dropdown menu.  The other view has to exist but does not have to be placed on a sheet.  When it is placed, the reference will update.  You can control wheter the Sim displays or not in the callout family settings.
Tue, Sep 30, 2008 at 3:58:22 PM | Reference View Tags not referencing actual detail number
clinard
Yeah figured it out, had to go into the element properties and delete "sim". The detail view # was showing up behind "sim".
Detail reference tags
Tue, Feb 7, 2017 at 11:22:08 AM
Details not Referencing Backwards
Tue, Mar 8, 2016 at 4:47:40 PM
Missing detail lines in a detail item tag I created
Thu, Jan 7, 2016 at 11:22:05 AM
Is their a way to change the Viewport referencing?
Wed, Sep 21, 2016 at 3:16:25 PM
Detail References
Wed, Apr 19, 2006 at 6:18:57 PM
Page generation time: 8.2412
