Forums >> General Discussion >> Wishlist >> Vertical version of Stonework Elevation.pat?
Tue, Sep 30, 2008 at 7:11:13 AM | Vertical version of Stonework Elevation.pat?
juul
Can anyone please make a vertical version of this hatch pattern, please? I had to give up after several hours, must admit I'm not the hatchpattern master I hoped to be...
Tue, Sep 30, 2008 at 7:52:05 AM | Vertical version of Stonework Elevation.pat?
robinballew
robinballew Avatar
3 Stars: 4 Votes
You can rotate the hatch "fill pattern" after it has been placed. Even a stone or complex hatch. Just select an element in the hatch and then click on Rotate. Type in 90 don't try and eyeball it..
BallewDesigns.com
Tue, Sep 30, 2008 at 8:47:54 AM | Vertical version of Stonework Elevation.pat?
juul
hey Rob
Thanks for a quick reply!!!
I tried your solution, but the hatch didn't rotate. I'm using Revit architecture 2009, so sorry if I ask foolishly: but is it an AutoCAD workaround?
-Lasse
Tue, Sep 30, 2008 at 9:00:42 AM | Vertical version of Stonework Elevation.pat?
You are using a 2d hatch.  Make it a 3d hatch and it will work.
You can make any hatch a model hatch by editing it in a text editor:
Add the line:
;%TYPE=MODEL
just after the name.
Tue, Sep 30, 2008 at 9:32:16 AM | Vertical version of Stonework Elevation.pat?
robinballew
robinballew Avatar
3 Stars: 4 Votes
Quite true..By 3D we mean "Model" Type pattern. All patterns that represent something real, Brick, Stone, Shingles, Tile should be Model patterns. All drafting symbols like Steel, Gyp., Sand, Conc, should be "Drafting" Patterns.
BallewDesigns.com
Vertical Plywood Hatch Pattern [ 1 2 ]
Mon, Aug 27, 2012 at 4:04:30 PM
17
Need help with a PAT file
Thu, Sep 29, 2011 at 12:55:36 PM
vertical plywood
Fri, Nov 25, 2011 at 8:26:44 AM
12
Import PAT File
Tue, Dec 14, 2010 at 9:42:43 AM
Reclaimed bricks
Tue, Jun 21, 2016 at 9:02:47 AM
Page generation time: 0.3119
