Forums >> General Discussion >> Revit Project Management >> Demo Plan Room Tags
Mon, Sep 29, 2008 at 5:58:28 PM | Demo Plan Room Tags
snaposda
How do you make existing room tags appear in demo plan/phases? The phase is set on "new construstion," phase filter is "Show previous + demo."  The walls show correctly as demoed walls, but the only room tags that will show up are the new constuction rooms' tags. How can we change the rooms/tags phase status to "demo"? Or at least make them show up once a room has been demoed?
Mon, Sep 29, 2008 at 11:25:34 PM | Demo Plan Room Tags
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I've achieved this in the past by overlaying views on the sheet.  That is, have another view set to Existing as the acting phase and have the room tags just displaying in that view and then overlay it.
Regards,
Chris.
Mon, Sep 29, 2008 at 11:27:16 PM | Demo Plan Room Tags
psymon
psymon Avatar
3.5 Stars: 6 Votes
Hi,
firstly, tags are not enities themselves, by that I mean they only show the attributes of a family or system object - in this case rooms, so the problem is not with the tags, but with the rooms.
Rooms are phase dependent. You cannot show a room that was created in the exisitng phase in a future phase.
You need to copy the rooms from the existing phase into the demolition phase, then also in the proposed phase if it doesn't change.
HTH
Sun, Jan 4, 2009 at 8:19:38 PM | Demo Plan Room Tags
thankyoufrankgehry
1 Stars: 1 Votes
Does this (copying the room tags into other phases) double/triple count the rooms in the schedule?
thanks!
(I am using 2009)
Sun, Jan 4, 2009 at 8:24:39 PM | Demo Plan Room Tags and shifting phases
thankyoufrankgehry
1 Stars: 1 Votes
Also, can the tags be shifted into different phases.  I accidently tagged my rooms in my new construction phase instead of the existing phase.  When I open up the earlier phase there are not any rooms associated with it.  I ended up deleting all of the rooms with the schedules (in both phases because some were tagged in both), but could there have been a better way?  When I open up the element properties it shows that the ROOM X is in the new construction phase, but it is "greyed" out--not letting me alter that property.
Thanks again!
Mon, May 9, 2022 at 3:26:22 PM | Demo Plan Room Tags
Ambrosio
1 Stars: 1 Votes
Understanding Rooms:
If any element that would change the parameters of a room (demo or new wall, new door, square-foot change, etc) were to change, the room information would become unstable so the room cannot extend beyond the static phase that it was placed in. If you think about it, every component in Revit is static, but with doors, walls, windows, or any other component, they are placed within a phase and remain unchanged until they are demolished. Any change between phases that would alter the static nature of a room (see above) would destabilize the room.
Setting up a Demo view in Revit 2022:
It is a workaround but the best I've found so far & it works in one view, rather than with multiple layered views:
1. Create a view of the existing phase with the phase filter set to Previous & New.
2. In Visibility/Graphics Overrides (In your view template if you will have multiple demo views), go to the Filters tab. At the bottom, click on the box Edit/New to modify document filters.
3. Create a new Rule-based Filter for each new construction phase of your project, calling it Demolition, or Demolition-Phase 1... (Make sure you have the new Filter set to Define rules).
4. Check every category that you may have items to demolish. (Some categories can't be added because they aren't phase specific)
5. Filter Rules: AND (All rules must be true), All Selected..., Phase Demolished, equals, Phase 1 (or whatever phase you are setting the filter for). Apply/OK.
6. Back at the Filters tab, Add your Demolition filter. Set your overrides in Project/Surface & Cut to show all of your demo items correctly in the view.
Remember: You will want to create a view template set for each phase & view type needed. Each view will be set to the existing or previous phase, allowing the correct rooms to show.
Thu, May 12, 2022 at 9:21:44 PM | Demo Plan Room Tags
AgentTiger
1 Stars: 1 Votes
Modify > Annotate >Text
Room/area tags on floor plan with demo'd wall
Tue, Feb 10, 2009 at 9:53:41 AM
Room Tags on Demo Plans
Mon, May 9, 2022 at 3:23:12 PM
room tags and demo
Tue, Apr 6, 2010 at 1:13:11 PM
Portion of Room tags show up in one plan but all show up in another...
Wed, Mar 19, 2008 at 11:41:50 AM
Room Tags on Reflected Ceiling Plan. Why so difficult!
Wed, Apr 4, 2007 at 4:21:33 PM
Page generation time: 0.4664
