Forums >> Revit Structure >> Technical Support >> How do you add a crank to a Grid Line?
Mon, Sep 29, 2008 at 4:55:43 AM | How do you add a crank to a Grid Line?
Allan1983a
Im using Revit Structures 2009 and am trying to Crank a Grid Line, does anyone know how to do this?
Cheers
Allan
Mon, Sep 29, 2008 at 7:04:11 AM | How do you add a crank to a Grid Line?
If you are asking what I think you are, click on the gridline and you will see a break symbol.  Click on that.
BTW - Learn to use your help.  It is very good and will help you with questions like this.  Just putting in grid will lead you to "Creating gridline offsets"
Curved/Arc Grid Line - NOT DASHED
Thu, Oct 13, 2011 at 11:22:19 PM
Column Grid Line Weight
Sun, Aug 13, 2017 at 3:05:53 AM
Grid Lines - Instance based text in grid line family
Mon, Jul 23, 2018 at 2:17:14 PM
Space between Grid Head and Grid Line not wanted!
Mon, Jan 28, 2013 at 4:14:54 PM
Curtai Grid - Add/Remove segment
Sun, Sep 7, 2014 at 9:34:13 AM
12
Page generation time: 0.5964
