Forums >> Revit Building >> Technical Support >> Wall schedule by apartment unit
Mon, Sep 29, 2008 at 3:41:43 AM | Wall schedule by apartment unit
lassek
I have a building with 50 apartment units, organized in groups one for each of the 5 different types. 50 units, 5 groups. I need to make a wall schedule per unit, ie apartment number xxx has this many walls of that type.
So how can I make it so the wall "knows" what apartment its in? The only wall instance parameter I can edit when the walls are grouped is "mark" and I need to use that parameter for something else. Is it possible to count walls within a room area?
Im using Revit 2009.
Any help appreciated!
Mon, Sep 29, 2008 at 7:14:49 AM | Wall schedule by apartment unit
Sorry, walls do not associate with rooms.  You can look into shared parameters but the data would have to be added and I doubt you can get what you want.
Apartment Groups - Ceiling heights
Mon, Jul 21, 2014 at 11:11:51 AM
Areas for rooms and apartment units
Thu, Sep 7, 2006 at 3:07:38 AM
Using Area Plans as Main Floor and Unit Layout plans
Mon, Mar 29, 2021 at 1:59:33 PM
apartment areas
Sun, Apr 20, 2008 at 10:31:50 PM
Schedules - Grouping by Unit
Tue, Nov 21, 2006 at 5:51:55 PM
Page generation time: 1.7008
