Forums >> Revit Building >> Technical Support >> Raised Floor Issue
Fri, Sep 26, 2008 at 10:24:21 AM | Raised Floor Issue
ckchambe
Hello everyone!
I'm wondering if anyone can help me with an issue I'm having with a raised floor I'm working on. We've create separate levels for the Top of Structure and for the Finished Floor elevation, 18" appart.  In order for our energy analysis program to run correctly, however, I need to place a room object in that plenum.  The problem I'm having is that  the partition walls are still acting as room binding even though they are based on the finished floor level with no off set.  I tried to off set the upper limit of my plenum room objects a couple inches below the finishe floor level to see if that would help and it proceded to tell me that my rooms had to be taller than 0" (by my math still over 1'-0" tall) and it put 9'-6" in the element properties, even though graphically my room object looked no different when I closed out of that window.  I'm attaching a pdf to show what I mean.
Thanks so much to anyone who has any ideas!
Fri, Sep 26, 2008 at 10:29:18 AM | Raised Floor Issue
4 Stars: 205 Votes
You forgot to attach the pdf....
Fri, Sep 26, 2008 at 10:32:45 AM | Raised Floor Issue
ckchambe
Sorry, I thought it attached the first time, but I guess not.  lets try againSmile
Fri, Sep 26, 2008 at 10:37:00 AM | Raised Floor Issue
ckchambe
Looks like it was too big, this should be better.....
Raised floor system
Thu, Jun 25, 2015 at 2:10:09 AM
Tiered Raised Access Floor - Revit 2013
Thu, May 9, 2013 at 7:55:28 AM
Raised floor
Wed, Jun 24, 2015 at 3:57:07 AM
raised floor
Tue, Jun 23, 2015 at 4:35:05 AM
Creating Raised Floor systems
Thu, Nov 13, 2008 at 11:49:31 AM
Page generation time: 1.4592
