16 Users Online (14 Members):
Forums >> Revit Structure >> Technical Support >> How to export 3D walls to Autocad?
42 Posts No Rating |
Hi! I have made a wall in 3D that consist of 3 materials, each one has a different surface color that can be seen in 3D. Can anyone tell me how can I export this 3D wall so finally when I'd open it in the Autocad, ther would be thre layers with different name or atleast one layer but the surface colors would differ? Does anyone knows how to do that? Best regards..
I'm sorry.. i thought i havent posted this question in this forum.. i asked it also in cadforums, but noone knows how to do that..
9 Posts No Rating |
Some ideas, 1.create subcategories and assign different parts to sucategories and control export in revit to different layers and color ids. 2. create different views with elemets hidden using element hide command or visibility graphics and export each view as seperate files and use xref command in acad to merge model back together.
One thing is that I have to get in autocad as a 3D. Other thing is, that all these thre materials are in one wall. One surface is yellow for example and another (interior) is blue.. What to do then? PS. Thank you for ideas!!!=)
Hi, i think you must update the new "Web Update 20080915_2100" for Revit Architectural 2009, like you can see in the Web update Enhancement list", they solve some issues to this version, this is the link: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11017599
Edited on: Sat, Sep 27, 2008 at 4:26:59 AM
WOW!!! I took a look at your picture attached... I'll try to update my version! I hope it will help.. Lots of thanks!!!
export to autocad |
Wed, Jul 6, 2005 at 7:41:50 PM
MEP AutoCAD Export issues |
Sun, Mar 13, 2016 at 12:46:02 PM
Revit to autocad |
Wed, Mar 1, 2006 at 3:04:23 AM
Lineweights in Revit to CAD Export |
Fri, Feb 23, 2018 at 10:58:32 AM
Export Revit to AutoCad |
Sun, Jan 15, 2017 at 1:42:15 PM
