Forums >> Revit Building >> Technical Support >> Floor Joist annotations
Fri, Apr 29, 2005 at 12:26:32 PM | Floor Joist annotations
johnfire
I downloaded some of the joists annotations and modified them but I cant seem to change the font style of [ 2"x 12" floor joists ] from the architect? that they were created in to an Arial font. How can this be changed? It doesnt seem that there are parameters that can be changed but when you select properties you can change the text but not the style. I doesnt look like there is a family type set up for that. I am sure that it is something simple but I cant figure it out. Help!
Fri, Apr 29, 2005 at 3:31:46 PM | RE: Floor Joist annotations
Bimman
Bimman Avatar
1 Stars: 2 Votes
it sounds like you downloaded the ones i made. the reson you can not change the text is because they are a labels you need to modify the label and then reload it into the family. i have attached the label so oyu do it. hope this helps. Pete AKA
PWD
Fri, Apr 29, 2005 at 3:32:32 PM | RE: Floor Joist annotations
Bimman
Bimman Avatar
1 Stars: 2 Votes
PWD
Fri, Apr 29, 2005 at 3:38:21 PM | RE: Floor Joist annotations
johnfire
That was it, thank you very much.
floor joist layout
Thu, Dec 22, 2005 at 6:14:54 PM
Joist Seats on sloped joists
Wed, Oct 24, 2012 at 1:27:46 PM
13
Diagramming Floor Joist Elements
Tue, May 21, 2013 at 5:20:00 PM
Sloped joist line type
Thu, Nov 25, 2010 at 12:25:02 PM
Beam Annotations
Fri, Sep 2, 2011 at 4:32:37 PM
Page generation time: 0.6370
