Forums >> Revit Building >> Technical Support >> Revit 2009- 'Cut-out' image for materials, faulty
Wed, Sep 24, 2008 at 4:10:54 PM | Revit 2009- 'Cut-out' image for materials, faulty
mbrecken
I have created a black and white jpg image for use in defining cut-outs/ perforations in a new material (black=voids).  I began
the new material based on the 'generic' render appearance.  However,  once i apply this image to the material properties under the
'cut-out/ perforation' section,  the entire material becomes transparent: the white sections of my image are not being understood
by Revit as solid in the material.  is there something I missed in setting  up the initial jpg that will solve this problem?  Some step
in the drawing/creating process, or perhaps in saving the file as a certain type?
Thanks...
Wed, Sep 24, 2008 at 9:22:40 PM | Revit 2009- 'Cut-out' image for materials, faulty
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hi, I've done this numerous times and have not experienced that issue.  Can you post the opacity map and outline what the material is?  It may be as simple as using a different base material...
Regards,
Chris.
Thu, Sep 25, 2008 at 8:35:27 AM | Revit 2009- 'Cut-out' image for materials, faulty
ojmiami
I have the same problem that mbrecken has... could somebody explain me the correct procedure to use the cut-outs/ perforations in a new material. Ehat kind of file do I have to create?
Thanks,
Thu, Sep 25, 2008 at 7:58:55 PM | Revit 2009- 'Cut-out' image for materials, faulty
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
A JPG is usually best.
Regards,
Chris.
Mon, Sep 29, 2008 at 9:06:53 AM | Revit 2009- 'Cut-out' image for materials, faulty
mbrecken
I've actually figured it out,  or at least one solution that did work.
The program I saved the jpeg in saved in CMYK format by default, without other options.
I opened the image in photoshop and saved it with an RGB color scheme (I noticed that the default
revit images were RGB when I searched their file properties).   The same jpeg saved in RGB worked fine.
Yes, it's that easy... hope this helps others!
Mon, Sep 29, 2008 at 4:13:56 PM | Revit 2009- 'Cut-out' image for materials, faulty
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Good detective work!
Regards,
Chris.
No ''materials'' properties on my object
Fri, Jun 18, 2010 at 11:57:28 AM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
When I cut a section or elevation in revit, it shows what's behind the cut plane
Fri, Dec 6, 2013 at 12:47:17 PM
Adding materials into Revit's materials files
Thu, Jul 22, 2010 at 1:54:48 PM
Revit 2009: detailings: tag that list all wall's materials
Mon, Oct 12, 2009 at 7:47:25 AM
Page generation time: 1.9530
