21 Users Online (19 Members):
Forums >> Revit Structure >> Technical Support >> stud and camber tag
19 Posts No Rating |
Dear all, i am hoping one of you can help me, i have a steel structure which has a numebr of different sized (in length) beams i am aiming to put the stud and camber size tag to each of the elements. however the tag has the beam size and the stud size as well as the camber size, this presents a problem with the drawing presentation, as i do not seem to able to move the stud/camber size without moving the whole tag. so how can i do this, i.e create a separate tag for stud and camber and maintain the link with the beam. or do i create a new parameter for these ? many thanks
What I have done is create new visibility parameters for each separate piece, then create new types for each different state. I never needed a tag with just the camber and studs and no beam size, but there is no reason why this method would not work for that.
Custom Structrual Framing Tags |
Thu, Sep 11, 2008 at 3:10:08 PM
Stud wall family help PLEASE.... |
Fri, May 9, 2008 at 1:09:58 PM
Parametric Line Extension...array or repeating line or...? |
Mon, Jul 2, 2012 at 3:00:35 PM
Stud Wall-Make finishes disappear |
Fri, Jan 30, 2009 at 5:24:09 PM
Single Timber stud to double stud wall doesnt wrap the plaster at the end. |
Wed, Aug 8, 2012 at 5:18:19 PM
