7 Users Online (5 Members):
Forums >> Revit Building >> Tips & Tricks >> Revit & Google Earth..
I am running Revit 2009 and have the Google Earth plug-in, allowing me to export/import between GE and Revit. Does anyone know if there is a way to actually import the topography from Ge into Revit. I know it is available in AutoCAD, so I would think it should be able to done in Revit, I would think.
Not directly, if you get the topo into cad, then bring that into revit. But I've found the topo from google is not accurate and very coarse. Its better to get the topo from the civil engineer or surveyor
You can import points using revit. Autocad reads points and try to import the points from autocad or use Civil 3D to import the points. Civil 3D is easier to maintain the points from google earth. DL a copy of civil 3d and GE imports the map and topo directly into Civil 3D. Revit imports the points directly from Civil 3D
Join Onedra.com Free online training using Autodesk Revit Architecture/ Structural/ MEP/ Autodesk Inventor/ AutoCad/ Architecture/ Alias/ Civil 3DUnigraphics/ Catia/ Adobe Photoshop |
Publish to google earth issue |
Sat, Feb 9, 2013 at 11:00:01 PM
Rotating a model imported into Google Earth |
Wed, Oct 24, 2007 at 8:54:53 AM
Revit into Google Earth COOL!! |
Fri, May 16, 2008 at 9:00:29 AM
Revit to Google Earth |
Mon, Feb 11, 2013 at 9:09:38 AM
Google Earth extension |
Mon, Jun 9, 2008 at 5:39:13 AM
