Forums >> Revit Building >> Technical Support >> RAC 2009 Walkthrough
Mon, Sep 22, 2008 at 11:07:11 PM | RAC 2009 Walkthrough
timglass
I have a walkthrough of a condominium.  I've set the DPI to 75 and the lighting to internal sun only.  The lighting for each and every frame has an almost water color effect - sort of circular patterns to the colors of the walls and floors.  Is this normal?  The walkthrough is fairly simple, has 300 frames, and took well over ten hours to render / export.  I'd share it, but it's 700MB.
Any help?
Thanks, Tim
Sun, Sep 28, 2008 at 10:51:33 AM | RAC 2009 Walkthrough
robinballew
robinballew Avatar
3 Stars: 4 Votes
I would test the rendering on the view prior to running the walkthrough. What you see is what you get. I usually run the walkthroughs at "high" for a good view.
BallewDesigns.com
Walkthrough
Thu, Sep 24, 2009 at 8:24:31 AM
Walkthrough query
Tue, Feb 17, 2009 at 8:45:56 AM
RAC 2009 Slow Down - Possible Fix
Sun, Jun 15, 2008 at 8:20:42 AM
Exporting Walkthrough Trouble
Thu, Apr 17, 2008 at 8:00:50 AM
Adding New Materials to the Render Appearance Library in RAC 2009? [ 1 2 3 ]
Fri, Aug 8, 2008 at 6:11:21 PM
31
Page generation time: 0.3491
