Forums >> Revit Building >> Technical Support >> Slow 'group' regeneration
Mon, Sep 22, 2008 at 2:09:07 PM | Slow 'group' regeneration
baumansara
Revit seems to be extremely slow regenerating when I edit and/or reload groups.  It can take up to 10 minutes....and sometimes there is an error and it needs to shut down.  Revit only seems to be slow when I'm dealing with groups.  Is there some trick to dealing with them?  My file size is around 60,000kb.  I've heard that files become hard to work in around 100,000kb.  Is that true?  Is there any way other than "purge unused" to shrink file size?
Thank you!
Mon, Sep 22, 2008 at 2:22:25 PM | Slow 'group' regeneration
coreed
coreed Avatar
4 Stars: 16 Votes
using groups excessively is one of the things that slows Revit down. have a read of this performance guide. it may be of help.
Edited on: Mon, Sep 22, 2008 at 2:22:40 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Create a new 'Group Parameter Under' category
Wed, Mar 25, 2009 at 8:26:51 AM
can't make change to group with more than one instance [ 1 2 ]
Sun, May 21, 2017 at 1:30:17 AM
16
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Revit 2013 slow performance in citrix
Wed, Nov 5, 2014 at 11:03:13 AM
Problem using 'paint tool' within copied groups - Revit 2013
Wed, May 22, 2013 at 2:43:14 PM
Page generation time: 0.4001
