15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Kite wind stairs
1 Posts No Rating |
Can revit 2008 deal with kite winder stairs? Can anyone help?
Seems to be fine in plan & elevation. Depending on the stair setup, model can get strange. I suggest you try it out and see what happens. Use the stair examples from the on-line library. Just open that rvt file - add your winders to one of the plans and see what happen. You can then use the eye-dropper to modify the stair type to see what does work.
Savonius wind turbine |
Fri, Apr 9, 2010 at 3:55:21 PM
Wind Bracing Attachment |
Thu, May 13, 2010 at 2:53:35 AM
New Project |
Wed, Oct 27, 2004 at 9:09:08 PM
Wind bracing panels |
Wed, May 27, 2009 at 5:43:16 PM
Total # of sheets/ Wind Category: creating to place on titleblock |
Tue, Dec 11, 2007 at 8:24:24 PM
