Forums >> Revit Building >> Technical Support >> Accessability problem
Mon, Sep 22, 2008 at 5:38:16 AM | Accessability problem
JGATOR
Working in Revit 2009, power goes out to the bldg while working. Computer re-starts and I open Revit 2009 and click on the file I was working on. A warning message comes up saying that there is another person using that file and any changes I make will not be saved. My computer is the only one that has Revit on it and we do not share files with anyone yet in Revit. I can be the only one using the file.
Since I have it backed up on a flash drive I try to delete the file I was working on. I am not allowed to do this either because the computer thinks it is being used. At this point I have closed Revit and I am still not able to delete the file.
It is early here and I plan on calling our IT guy but does anyone here know a fix?
Mon, Sep 22, 2008 at 7:51:50 AM | Accessability problem
Was this a workset file?  Should not have been if you were the only one.
Just open and do a save as giving it a new name.
Mon, Sep 22, 2008 at 8:39:32 AM | Accessability problem
JGATOR
Not a workset and I'll try your suggestion. Thanks
Basic problem
Tue, Feb 26, 2013 at 7:29:28 AM
rendering problem with windows
Fri, Jan 13, 2012 at 3:31:28 PM
Revit 2009 Rendering Problem(Black screen) [ 1 2 ]
Mon, Apr 1, 2013 at 2:45:28 PM
27
Roof Problem
Sat, Mar 9, 2013 at 10:01:25 PM
13
Strange problem !!! hlp plz
Thu, May 29, 2008 at 4:14:42 PM
13
Page generation time: 1.8950
