Forums >> Revit Building >> Technical Support >> Loading imported file crashes Revit 2009
Fri, Sep 19, 2008 at 10:50:07 PM | Loading imported file crashes Revit 2009
johnalgeo
I am using Revit 2009.  One file will not load and seam to crash when updating linked acad files.  I have loaded the back up and local copies of the file and the same crash happens.  Is there any way to unlink the acad files prior to launching the file.  The error report to Autodesk has not come back with a solution.
Thanks as always.
 JSA
john a
Sat, Sep 20, 2008 at 6:50:40 AM | Loading imported file crashes Revit 2009
4 Stars: 205 Votes
Hi, did you try "Audit" the file when you Open??
Edited on: Sat, Sep 20, 2008 at 6:53:45 AM
Mon, Sep 22, 2008 at 10:55:37 AM | Loading imported file crashes Revit 2009
johnalgeo
Yes, I ran audit on all the files and back up files.
 Thanks
JSA
john a
Mon, Sep 22, 2008 at 1:15:08 PM | Loading imported file crashes Revit 2009
4 Stars: 205 Votes
Houston, we have a problem...
Mon, Sep 22, 2008 at 7:26:18 PM | Loading imported file crashes Revit 2009
johnalgeo
I went to the backup tapes and uploaded a file that was a week old.  Took a chance and did "Reload latest"  I worked.  I unloaded all the linked files so it should be fine.
 Somebody from AutoCadd owes me a beer at AutoCadd University.
John Algeo
john a
Tue, Sep 23, 2008 at 2:51:24 AM | Loading imported file crashes Revit 2009
4 Stars: 205 Votes
Good for you...
Thu, Feb 12, 2009 at 1:06:13 PM | Loading imported file crashes Revit 2009
InfiniteRevitArch
Hello RevitCity croud. Our Office incountered the same issue that REVIT 2009 crashed when booting and "updating references" We tried many different solutions to no avail, but in a last ditch effort we opened the problem file in Revit 2008 and exported back to Acad then Referenced back into Revit 2009, and it was a success. I hope this solution helps anyone.
Fri, Feb 13, 2009 at 9:13:32 AM | Loading imported file crashes Revit 2009
notagain
notagain Avatar
4 Stars: 1 Votes
one thing we have done here...and we are workig in R8-we export via IFC and import that way...seems to work for all cad applications, having several to deal with...it comes across in Revit being clean...you might want to give that a shot
I really want this to work...some good things some bad
Revit 2009 file preview is not available
Fri, May 2, 2008 at 1:41:45 AM
Section through a family object and imported dwg file
Fri, Mar 26, 2010 at 12:41:24 PM
New Revit 2011 - Crashes upon loading
Fri, Aug 6, 2010 at 4:24:20 PM
Opening 2008 file in 2009 causes "Unrecoverable error" crash
Tue, Jul 28, 2009 at 1:36:33 AM
provided by vendor - errors?
Tue, Jun 23, 2015 at 3:35:14 PM
Page generation time: 3.0824
